Gas in 2 stroke banshee
Old May 9, 2005 | 12:43 AM
lninjorider's Avatar
Default Gas in 2 stroke banshee
Accidentally put regular gas in my banshee with out mixing oil. Ran for 2 days and just quit tried to tow start it and it would only stay running with the clutch in can anyone help please im begging you what should i do
Old May 9, 2005 | 12:50 AM
CountryJoeGlass's Avatar
It's time for a rebuild if you ran it without mixing oil in the gas.
Old May 9, 2005 | 01:11 AM
How much does a rebuild run and would it be something I could do my self
Old May 9, 2005 | 01:15 AM
bluebansh's Avatar
depends on if u scarred the cylinder walls, i rebuilt my shee faily cheap like within a couple hundred dollars, but u might need to bore if it has any scarring. as for doing it urself, i dunno, thats ur own call, how well are u at working mechanically. I had mine tore down and done in a saturday but ive also been around engines being tore down all my life.
Old May 9, 2005 | 01:20 AM
ehlitdew's Avatar
Its difficult to do a rebuild yourself, unless you have done it before many times.
If you give it to a professional workshop, it will cost ya, say on average something like 1,000 <---> 2,000 bucks.
Old May 9, 2005 | 01:27 AM
Would that also have an effect on the clutch. It would only stay started with it in when were pulling it to get it started then it quit. It also seems it lost compression when trying to kick start. Basically could that effect the clutch also. Thanks for the help
Old May 9, 2005 | 01:48 AM
quicksilver's Avatar
running it on straight gas would not hurt the clutch at all. You probably took out the crank bearings and cylinder/piston of the engine tho.
Old May 9, 2005 | 01:56 AM
ehlitdew's Avatar
Hey lninjorider listen to me, do as I tell you,
give it to a good workshop, say he will tell you it will take a week to fix it,
after the week is over go and pick it up and pay your 1,500 bill,
then go and ride your shee,
so what do you think of my opinion.
Old May 9, 2005 | 02:10 AM
If the cylinder walls are scarred couldnt I have it bore out for more horsepower and what kit would you recommend
Old May 9, 2005 | 02:15 AM
ehlitdew's Avatar
lninjorider don't waste your time, just fix it and go and ride, Obey Me LOL.
