A few questions
Old May 10, 2005 | 09:00 PM
Pelphrey's Avatar
Default A few questions
What grease should I apply to the fittings on my 01 warrior? If grease isn't the answer then correct me please. The front end is starting to squeak a little bit when I turn the wheels and push down on the front. Also what is the best way to clean my air box out, with the filter out of course. If I take the bottom drain bag off can I spray it out?
Old May 11, 2005 | 12:37 AM
buckshot12's Avatar
chances are one of you're shocks are squeaking. trust me, it won't quit until you unbolt it and spray lube on the bolt and fitting. use chain lube. if you clean out the air box just make sure the carb is covered. stuff it with a rag and don't use a pressure washer
Old May 11, 2005 | 02:34 AM
Pelphrey's Avatar
Nice so the chain lube can be used on other parts besides the chain. I appreciate the help. Thanks
Old May 11, 2005 | 06:58 PM
buckshot12's Avatar
it worked for me. oh yeah......make sure it's the stuff that gets tacky after a few minutes
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
