Calling Wolvydude - re: Kenda Bear Claws in 24"
Old May 11, 2005 | 12:33 AM
trahsub's Avatar
Default Calling Wolvydude - re: Kenda Bear Claws in 24"
Yo man, I can't find the right fitment in 24" bearclaws. What do you have on your F and R? Did you do the 24 in front and the 25 in back?
Old May 11, 2005 | 08:48 PM
Blaster96's Avatar
DO NOT PUT (edit: two) DIFFRIENT SIZE TIRES ON A 4x4.....
You will over stress the drive line and will cuase parts to break (namely the u-joints) and wear out the front and rear ring a pinions. I would suggest going with 25's all around. Also, the narrower the front tire the easier it will be to turn.
Old May 12, 2005 | 09:00 PM
CTATV's Avatar
blaster96 i am going to imagine you were saying dont change the tire size ratio as in 24 up front 25 in the rear when the ratio was 1 to 1 with 23 front 23 back in stock form. If your saying dont change tire size at all your wrong.
Old May 12, 2005 | 11:33 PM
Blaster96's Avatar
You are correct on all accounts. Putting a 24 up front and 25 in the rear would be like putting diffrient ring and pinions in the front a rear Diff. in a Jeep. You are just going to grenade something. Heck, I think the stock 23's are not tall enough and are less than desireable. One of the first things I did on my machine was up them to 25's.
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
toonces
Sep 9, 2015 03:28 PM
black_thunder
Sep 6, 2015 04:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
