Raptor 700
Old May 27, 2005 | 09:30 PM
CTracingraptor's Avatar
Default Raptor 700
raptors come in two pistons a 686 or a 727, a 700 would have to be custom made.
bigger is not better, some times the whole no replacement for displacement can be misleading, but it is true but their are ways to sneak out 67hp out if a stock bore, on pump gas.
Old May 27, 2005 | 10:38 PM
2phast4u's Avatar
Default Raptor 700
thats for sure that also had a trx450r xc racer w/ just hrc cam and airbox mods and a alba exhaust stock gearing and the rider claims just over 80mph i think thats pretty damn good
Old May 28, 2005 | 12:37 AM
Default Raptor 700
whats with you people and this mph, junk??? i dont understand why it matters. every f-ing bike can go 80 with the right gearing.. its how fast you get their that matters, and that wheres HP comes into play. top speed dont mean a thing.....
Old May 28, 2005 | 02:00 AM
spudley's Avatar
Default Raptor 700
67 hp?, stock bore? How and how much.
Old May 28, 2005 | 02:03 AM
  #15
bassetboy55's Avatar
Default Raptor 700
back after a long time.
Old May 28, 2005 | 07:59 AM
  #16
2phast4u's Avatar
Default Raptor 700
i never said 80 was alot im saying w/ little mods and not going to crazy u can still get some where u dont havfta bore it out to 700cc's to go fast or make power
Old May 28, 2005 | 10:08 AM
  #17
Warrior02man's Avatar
Default Raptor 700
the rappy is already tippy as it is.. how the hell r they makin a 700? They changing the whole bike including the frame? or r they just putting a bigger motor on it.. because that could be a big problem.
Old May 28, 2005 | 01:45 PM
  #18
Default Raptor 700
700 aint nothing my friend. oh how if you only new. raptors are currently running 820 kits in them.
spudley if you want to know how then PM me.
Old May 28, 2005 | 02:43 PM
  #19
MichaelAZ's Avatar
Default Raptor 700
Call Kenzcycle tech 480-962-1714 , I dont know how much but I do know Howardstern has made that on a stock bore.
Old May 28, 2005 | 02:52 PM
  #20
MichaelAZ's Avatar
Default Raptor 700
Well A few things, first it sounds like you ride a KFX 400 and before that Id say a warrior so a few things
1)CC has absolutly NOTHING to do with "tippy" , if I put a 50 cc in my raptor would that make less "tippy" ? See how silly that statement you made is.
2) You dont need to change a frame for making a quad less "tippy" , simply add wider A-arms,wider axle and a longer swing arm.
Once again ,See how silly that statement you made is.
3) Raptors are being built into the 800 CC's in the same stock frame. Raptors are being turbo'ed, and some run on NOS, as in fast n furious.
4) Come to Glamis sometime and you will experiance something you have never seen in your life, semi's hauling truck loads of quads from back east,900HP buggies, 100+HP banshees,80 HP raptors and none of it is "a problem" [img]i/expressions/face-icon-small-wink.gif[/img]
I'll see you there.
