Raptor 80 Problem..help!
Old May 29, 2005 | 06:29 PM
tenx2's Avatar
Default Raptor 80 Problem..help!
I bought this quad last spring. Even at the dealer, he noted that it was "coldblooded." He was right. The thing is on choke for a long time before it will run without the choke on. Any ideas? Any help would be great. Thanks for your time. Good day.
The idle screw is almost all the way in, just to keep it running.
Old May 30, 2005 | 12:32 AM
NBake's Avatar
try turnin the idl screw up, i had to do that to my honda cause that was really cold blooded. but when i put a pipe on it started alot easier[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 13, 2005 | 09:22 PM
61669's Avatar
i have a 2003 raptor 80 (daughters) i had the same problem.i just added an fmf pipe & the thing starts right up.i ha d a problem w/ it being to lean & would cut off if i hit the throttle but i went to an 85 jet & raised the needle to the last notch then had to adjust the air screwTHe one w/the rubber plug over it . it starts right up and runs like a champ
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
