yamaha wolverine hp?
Wolverine stock, 18-20 HP.
Mods...as for the motor, just about anything from the connecting rod up on a Warrior will also work on the Wolverine. The top of the motor is the same.
A good pipe and air filter set up makes a noticeable difference, especially if going to 25" tires. Once you do the pipe and filter, you will probably have to go up at least 1 jet size on the main.
A Warn 424 is the #1 mod for the Wolverine (in my opinion). Getting the Wolv in 2-wheel drive makes it that much more fun to ride.
Some of these other Wolv / Warrior guys can give you some more info on the different stages of engine mods and the difference they felt it made (cam by itself, piston by itself, carb, head work...you get the picture).
I chose to go all the way at once, with the FST 435 Stoker kit. Worth every penny...but it takes a lot of pennies : )
