What Is Better Pipe? Yoshimauri or GYTR?
If those are your only two choices go with the yosh. I typed in yfz 450 exhaust or pipes and got a @$$ load of threads. check that out as well. I have the hmf and i think it is great but there are others such as dr d and so on. so check that out as well bc you probably wont get many replies on this topic[img]i/expressions/face-icon-small-frown.gif[/img]
ILL REPLY TO YOU CHECK MY PICS I HAVE YOSHI PIPE FULL SETUP GOT IT COMPLETELY FOR 400 SHIPPED IF YOU are thinking between the two gytr is like enterence level on pipes yoshimura rocks i fell they out perform any other pipe now being the loudest not sure.. i run a spark arrestor in cali so loud enough for me though... #1 on my list #2 would be sparks
sparks, yoshi, Dr. D, HMF,... all good pipes with good gains from what ive heard. even tho the GYTR is genuin yami tech i dont think its the best. havent heard a lot of good things about it but im sure it has significant gains over stock... my uncle has an alba exhaust. its the same one kory ellis uses i think... but not his signiture pipe. ive also heard that yoshi is expensive. good luck!
both are good. both add more power. both make your quad sound about 100% louder as well. there both aftermarket pipes and that means they are both better then stock.... but comparing them? i heard the yoshi is better.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
