yz 125 question - PLEASE HELP even though its not about quads
Old Jun 6, 2005 | 08:55 PM
Muddkid12's Avatar
Default yz 125 question - PLEASE HELP even though its not about quads
When i start my YZ 125 it will only start with the choke up. Once it starts if you push the choke down it will stall. So I leave it up fer a couple minutes until it warms up. Then you have to give it throttle just to keep it running. When you go it runs great until you let off the gas and it starts to bog down like it wants to stall. My uncle says its somethin with the carb. any HELP that can be provided will be appreciated.
Thank you.
Old Jun 6, 2005 | 08:57 PM
sned's Avatar
make sure everything is tight it sounds like an air leak
Old Jun 6, 2005 | 09:18 PM
Muddkid12's Avatar
thanks, anyone else have any ideas???
Old Jun 6, 2005 | 09:33 PM
NBake's Avatar
u play with the idle? some 2-strokes are finiky about their idle adj. maybe ur pilot is clogged if it bogs when u let off the throttle. it sounds like either ur pilot jet is clogged or u have an air leak somewhere after ur carb.
Old Jun 6, 2005 | 09:37 PM
DirtRyder420's Avatar
yea it sounds like some kinda carb problem to me ,i would pull the carb off and clean it good you should also pull your reeds out and inspect them look for gaps between the reed and the reed cage
Old Jun 6, 2005 | 10:08 PM
YFZRyderMace's Avatar
Your jets might be messed up but it is definately something wrong inside the carb..
Old Jun 6, 2005 | 11:38 PM
Muddkid12's Avatar
Thanks for all your help I am bringing it to the local repair shop soon to see what they think.
Frisky2050
Apr 9, 2020 11:19 AM
1966F100
Jul 12, 2015 03:08 AM
200es
Jul 10, 2015 09:09 AM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
