Do I need Yamaha tappet wrech for valve adj?
Old Jun 27, 2005 | 01:35 PM
gsxr150's Avatar
Default Do I need Yamaha tappet wrech for valve adj?
Hi there, do I need to order the tool from my local dealer to adjust my valves? I have a 2000 Warrior. I checked in the archives and could not find anything about the tool. I think one person said they used a feeler guage and needle nose pliers?
Would you suggest buying the tool, or just getting a specific size in craftsman?
Old Jun 27, 2005 | 01:46 PM
hondabuster's Avatar
Im not positive about the sizes, but sears has what you need. The locknut is probably 8 or 10 mm, and the adjusting stud is probably 3 or 4 mm. You might even be able to get a small cresant wrench in there.
The only odd thing, is the adjusting stud is 4 sided ( square), so you need to use the open end of the wrench, the box end wont work..but its not a big deal, once the locking nut is loose, the stud will move just with finger pressure.
Old Jun 27, 2005 | 01:54 PM
gsxr150's Avatar
I see your in Minn... What part?
So I called the dealer and was quoted $156 for the valves. They wanted $234 + parts for a full tune up. Since I already have the plasic off, I might as well do it myself. I need to order a coupple of things from the dealer anyhow, so if the tool if only a coupple bucks I'll probably grab it. I should have a 8 to 10 mm wrench for the lock nut...
I just bought the machine and it's a 2000. I figure I'll do the valves, clean and lube the chain (clearance as well), grease everything, an oil change, and be ready to rock.
Old Jun 27, 2005 | 02:41 PM
quad2xtreme's Avatar
MotionPro sells an entire set that works for various bikes/quads. You really don't need it though. You can't torque to proper values though using the MotionPro set. Not sure about the factory tools.
Old Jun 27, 2005 | 02:54 PM
gsxr150's Avatar
I just talked to the guy at the shop again, and he said it's a good idea to have that tool since you need to hold that bold to loosen the lock-nut. He said there is not much room to move around in there... I'll probably just buy the thing it sounds like.
Old Jun 27, 2005 | 05:25 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
at MOST you would have to spend is like $15 and about 30mins of your time to do it.. do a search for posts that i made about valve adjustment.. i posted a how-to on it a few mothns ago...
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Aitch
Jul 21, 2015 09:40 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
