a question about YFZ 450 Pipe!
Old Jun 28, 2005 | 01:16 AM
YamahaForLife's Avatar
Default a question about YFZ 450 Pipe!
what is better, i got a yfz 450 and want to get a yoshi pipe..... whats the difference between me getting a slip on yoshi pipe or a full system pipe?
Thanks!
Old Jun 28, 2005 | 01:50 AM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
If you go with a full system, you wont have any lunch money left! J/K! Well, what I know is that the power increase with the header, will be aaround 1-5 ponnies, around there, it's just a calculation! And if you with with the slip-on, you could save some money and buy yourself a better air filter!
Old Jun 28, 2005 | 02:32 AM
blindside350's Avatar
Agreed, the stock YFZ header is fine unless you are going to do some big bore. Save the 200 and get a quaility air filter (UNI or K&N) some protection (Swingarm skidplate) and some lunch!!! lol
Old Jun 28, 2005 | 03:10 AM
MrP's Avatar
MrP
IMO I would go ahead and get the full system. I would also get either a Pro Design or Sparks air filter kit. In the long run I think you will be happy you got the full system.
Old Jun 28, 2005 | 06:11 AM
vinny3299's Avatar
not only that the header is designed for the pipe your buying and also the yamaha header was designed for the pipe that came on with you could possibly have air leaks off it sometimes they dont fix exactly so and i have a yoshi full exhaust on mine and the head and pipe have these springs to clamp on so you know it wont fall off and be a perfect fit... also a little lighter too but not a lot... the two headers that is
Old Jun 28, 2005 | 12:11 PM
Yea i can see its designed header/silencer but airleaks? Honestly the pipe isn't going anywhere, its bolted down and crammed into the header. Yoshi is a good company i wouldn't worry about air leaks.
Old Jun 28, 2005 | 12:14 PM
vinny3299's Avatar
well i was meaning air leaks as in using stock header on the yoshi pipe thats all but i wouldnt worry about it much... save the cash and just get a slip on...
Old Jun 28, 2005 | 10:02 PM
vinny i tried to add you to my yahoo, dunno if you got or not but try to add me to your yahoo list... need some advice from you if you dont mind, my yahoo username is : Jimmyahcrackahcorn
just msg me sometime, Thanks!
Old Jun 30, 2005 | 03:56 PM
BombSquad450's Avatar
Im going with the carbon fiber yoshimura full system, but im not getting it untill late this summer.
Old Jun 30, 2005 | 04:07 PM
2phast4u's Avatar
i dont think they would make a slip on if i didnt fit the stock header
