RAPTOR - MOTION PRO WITH FCR CARBS
Old Jul 26, 2005 | 12:32 AM
RaptorOwner's Avatar
Default RAPTOR - MOTION PRO WITH FCR CARBS
Originally posted by: UBETRUN
I put a cheap CR throttle on my Raptor with 39s and it works like a champ. One cable, no push-pull. A set of dual 39s has plenty of throttle return spring pressure, my throttle slams shut when I let off the grip.
I went everywhere in my town even when I was out of town and know one could give me any info on this CR throttle at all. I wish you had a part number cuz I was looking for this like crazy.
Old Jul 26, 2005 | 03:37 AM
Yamaha660R's Avatar
I'm doing good.....got a new truck(pic's in gallery), and yes...we are into the motor. I went to the dunes in Michigan and bent a exhaust valve. So Bob has the entire motor as we speak. [img]i/expressions/face-icon-small-wink.gif[/img]
Also powercoating the frame, and doing a ground up clean up and rebuild. Should be very impressive in a couple weeks.
Old Jul 26, 2005 | 03:48 AM
XR650Warrior's Avatar
Be sure and bring it to Sand-Fest in Okla. sept. 16 and 17th and try it out, some of the best runners will be there. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 26, 2005 | 07:44 AM
UBETRUN's Avatar
Originally posted by: RaptorOwner
Originally posted by: UBETRUNI put a cheap CR throttle on my Raptor with 39s and it works like a champ. One cable, no push-pull. A set of dual 39s has plenty of throttle return spring pressure, my throttle slams shut when I let off the grip.
Go to the parts counter and ask for a Honda CR 125 throttle.
Old Jul 26, 2005 | 11:22 AM
  #15
I did at my local Honda dealer but they didnt have any. I may try it again at the smaller independent dealers.
Thanks again
Old Jul 26, 2005 | 04:25 PM
  #16
CoyoteRiverRaptor's Avatar
RO, if you have trouble with the aftermarket you can go here and look at the pull down menu under motorcycle then parts. It is a micro fiche style slide with part numbers. I just checked and it is down right now but, I use it all the time.
http://www.planethondaracing.com/
CRR
Old Jul 26, 2005 | 11:23 PM
  #17
Thank you !!
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
