Problem with Raptor 350!! Help....
Old Jul 22, 2005 | 06:46 PM
delta5320's Avatar
Default Problem with Raptor 350!! Help....
Hi,
I had my raptor 350 put away for a about 4 - 5 months and I just took it out a couple weeks ago to start to ride it again. It started up pretty fast, but I notice some problems when I started to ride it.
First, when I'm in lower gears, the engine seems to sputter (almost sounds like it's going to backfire ) and cuts out really quickly. Basically just stalls.
I first thought it was my air filter, so I washed it out and re-oiled it...still the problem persists..
Now in addition to the cutting out....it makes a knocking sound every now and then..
Any idea what I could check for???
Thanks in advance.
Old Jul 22, 2005 | 07:16 PM
HooPharted's Avatar
drain the gas tanh,and put some fresh gas in it
Old Jul 22, 2005 | 07:17 PM
HooPharted's Avatar
soory,,,"gas tank"
really sounds like bad gas from sitting
Old Jul 22, 2005 | 07:20 PM
delta5320's Avatar
Is there any easy way to do that? Siphoning?
Old Jul 22, 2005 | 07:25 PM
HooPharted's Avatar
you can drain it from the line coming out of the bottom of the tank,,,you also may want to put a new fuel filter while your at it (if you have one)
5 months isnt really long enough to worry about varnish,,,so once you drain the tank,and put some fresh fuel in,start it up,and give it a couple minutes to let the fresh fuel to clean out the carberator out while its running
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
