motor cooler
Old Jul 26, 2005 | 08:30 PM
KRAZYKRACKER's Avatar
Default motor cooler
have any of you guys seen this part on ebay
you cut out a section of radiator hose and replace with
a piece of billet aluminum and motor runs 10 to 15 degrees cooler
i havent seen nor heard of this part anywere else
it goes for about 30$
what do you guys think
Old Jul 26, 2005 | 08:53 PM
garrett5462's Avatar
yea, i have seen them alot like at denniskirk and rockymountain. The fins will disperce some heat just like the fins on air cooled engines.
Old Jul 26, 2005 | 08:55 PM
which cools the antifreeze/water after its allready been through the radiator
Old Jul 26, 2005 | 09:13 PM
HooPharted's Avatar
so if it makes your engine run cooler,wont that increase HP?
heat robs HP doesnt it?
Old Jul 26, 2005 | 09:22 PM
i guess it would because i found online a little thing for like 30 bucks nd all it was, was a different sensor than the stock one thats in the radiator which controls when the fan goes on. It says it makes the fan go on at a little lower temp causing the engine to run slightly cooler. It also said a 2-4 horsepower gain or something.
Old Jul 26, 2005 | 09:44 PM
do you know any body that has used either of these products
Old Jul 26, 2005 | 09:48 PM
HooPharted's Avatar
no,first ive heard of these as well
my grizz get pretty warm at times,,,,and i always thought heat loves to rob you of pony's
Old Jul 26, 2005 | 10:11 PM
Raptor700R's Avatar
Bah alunimun in a rad house cant be good, at least i think. Just get watter wetter i use it and do notice a differance from when the fan kicks on and it dosenst run as much.
Old Jul 26, 2005 | 10:39 PM
MasterRaptor's Avatar
I concur. I have one of those, couldn't tell a difference, but it looks cool (No Pun). I could tell the difference after using "Engine Ice" coolant for $15.
Old Jul 26, 2005 | 11:08 PM
i dont know anyone that has used the sensor either. i think i saw it on an ebay store.
