What is the best oil premix ratio for new Blaster engine break in???
Old Jul 27, 2005 | 10:49 AM
Blaster2005's Avatar
Default What is the best oil premix ratio for new Blaster engine break in???
I'm getting ready to assemble my Blaster engine and would like to know the best premix ratio for engine break in. I normally run 32 to 1 in my other two strokes. However, on break in it may need a richer mixture. Any advice would be appreciated!
Old Jul 27, 2005 | 02:02 PM
Storj's Avatar
Run the same mix that you run regularly i just did my blaster top end and am running 32:1 which is a little rich but its what i always run
Old Jul 28, 2005 | 10:27 AM
Duneaddict's Avatar
Don't use a diff ratio for break in.
Grab the oil bottle of your choice, and see what the manufacturer recomends for that particular formulation. Stick to that ratio and you'll be fine.
Keep in mind that if you change oils/ratios that rejetting may be necessary.
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
