hmf pipe glowing!
Old Jul 30, 2005 | 04:10 PM
dragraptor's Avatar
Default hmf pipe glowing!
is a hmf header pipe suppose to glow the first time you start it?
Old Jul 30, 2005 | 04:26 PM
AZDUNERAT's Avatar
Most afermarkets glow a bit, hell the stock YFZ header lit up like a christmas tree. You might need to go up a size on the pilot jet though
Old Jul 31, 2005 | 04:51 PM
YamahaForLife's Avatar
ya alot of pipes do that occasionally but nothing that should worry you to much
Old Jul 31, 2005 | 06:29 PM
TRIPLELSTROKER's Avatar
If you didnt re-jet after installing the pipe you are probably too lean! The better flowing pipe lets the engine pull air through so much faster and easier the stock jet usually isnt large enough to allow the correct mixture of gasoline to go through with the air. This is a too lean condition and can cause a lot of engine damage. Ride it kind of hard, let it cool down and pull the plug and see what color it is. Should be a light to medium brown. If its white, it is definately too lean. I have installed several pipes and kits here in my area, around 1000 feet elevation. The instructions with the pipe and jet kit tell you what size jet you should use for your elevation. Usually it is up 2 sizes larger than stock. Just what I have ran into. Hope the info helps. You will be a lot better off with a too rich condition that a too lean as far as engine and piston life are concerned.
Old Jul 31, 2005 | 06:58 PM
dragraptor's Avatar
i rejeted it already, i pupt a 146 and 148,4th clip on the needle,3 turns out on the air mixture screw
Old Jul 31, 2005 | 07:38 PM
Warrior02man's Avatar
usually if u put a slip-on on a bike, ull neeed to rejet or ull see the glowing, which is caused by running lean. u need to step up a jet size to allow more gas to be mixed.
U said that u have an HMF.. correct? they say u dont need to rejet.. so i didn't and my warrior runs fine with it not jetted. i guess its because of the altitude or the fact that ur machine was a tad bit on the lean side to begin with.
just get it jetted.. u dont want to have to replace ur parts over a cheap thing like jetting.
Old Jul 31, 2005 | 10:56 PM
Since you have already rejetted the carb, what color does the spark plug burn now?
Old Aug 1, 2005 | 07:42 AM
Ozark38's Avatar
If your running without the lid you'll need way bigger jets than that with a full HMF.
Old Aug 1, 2005 | 01:28 PM
CHECKSIXS's Avatar
Yep.
Old Aug 1, 2005 | 02:54 PM
dragraptor's Avatar
im running a lid on it, i have a k and n powerlid but i cant get the jets right for it, i must have rejetted it 6 or 7 times
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
Bigtwin700
Sep 9, 2015 09:32 AM
