YFZ sputtering
Old Aug 7, 2005 | 02:55 AM
cr125predator's Avatar
Default YFZ sputtering
My buddy has a YFZ and has a factory 4 pipe on it, he has been riding with it quite a few times with the pipe and has no problems up until this weekend. He said that there was no problem in the bottom, but when he goes to pin it, it sputter, has no power, and wants to cut out. He had the dealer re-jet it when he first got the pipe. I dont know if this is good, but they put a 146 Main. is that too small? any help is appreciated
THanks
Old Aug 7, 2005 | 03:06 PM
HughJazz's Avatar
He should be at about 165-170. that is way smaller than stock. Stock is 158
Old Aug 11, 2005 | 12:19 AM
so if it was too small could it have F**ked up his motor?
Old Aug 11, 2005 | 01:00 AM
TheTurtle's Avatar
NEVER go to the dealership for work that is not covered by warranty. local private shops will do good work so you will come back again. stealerships f*ck your **** up so you have to come back!
Old Aug 11, 2005 | 02:35 AM
HughJazz's Avatar
It could if he keeps riding it that way. It will run really hot and eventually melt a hole in the piston
Old Aug 14, 2005 | 05:09 PM
But the instructions he got with the pipe said to put a 142 in, and then he went to their website and it said 152.
and when he put the 152 in it wont start.
Old Aug 14, 2005 | 09:28 PM
HughJazz's Avatar
Goto http://www.yfz central.com/invision/index.php?showtopic=908&st=0 Without the space between z & c
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Hw00d
Sep 10, 2015 08:53 AM
