if the beartracker has less power than the timberwolf then why did the discontinue th timberwolf
Old Oct 19, 2000 | 07:10 PM
RickSoto's Avatar
Old Oct 19, 2000 | 07:28 PM
snowshark's Avatar
Rick,
You should post this in the Yamaha forum.
Old Oct 19, 2000 | 08:38 PM
MojaveJordan's Avatar
the timberwolf and the beartracker have the same engine and power output
RickSoto's Avatar
i did but i also thought hat some guys in this forum would know to
Old Oct 19, 2000 | 10:33 PM
puddding's Avatar
the beartracker was just and 'update' of the timberwolf.....not a lot of difference....if anything was done it would have been an improvenment in the consumer eye........
its call extending the product life cycle......maximising there research and development cost of making the bike
maybe the image the timberwolf gave in the market place wasn't the greatest...ie. may have discovered to have a weakness....so they may have resolved the problem.....changing the name is like starting from a clean slate
Old Oct 19, 2000 | 10:34 PM
WV250R's Avatar
Where did you hear that the Beartracker had less power than the Timberwolf?? Nothing could have less power than a Timberwolf. Actually, I recall that Yamaha said that they had improved low end power on the Beartracker when they introduced it.
Old Oct 20, 2000 | 03:57 PM
JHAM's Avatar
The t-wolf was one of the industries top sellers. In fact, Honda came out w/the Recon just to capture some of that market. I had a 92 model and it cranked. It would hall 400lbs of hunters all day and not skip a beat. I paid $2900.00 for it out the door and sold it in 1998 for $2500.00. The Beartracker is basically the same bike, gobs of low end power.
Old Oct 21, 2000 | 09:21 PM
PimpedBanshee69's Avatar
i do believe that they put a larger carb. on the bear tracker,
chris
Old Oct 28, 2000 | 01:05 PM
MUDMAN03's Avatar
haha, 400 lbs of hunter!? thats all. mine can pull a 1/2 ton trailer w/ a 500+ gallon water tank filled with water easily and i have not modified it in any way. and i was runing stock tires then but i am not now.
Old Nov 2, 2000 | 08:48 AM
Harold's Avatar
diff. carb. and a diff. cam, which yamaha said gave the beartracker more hp,BUT, the timberwolf had more torque.
