Blaster reed help.
Old Oct 19, 2000 | 09:30 PM
hotfmfblaster's Avatar
I pulled out my blaster's reeds and found that one was .020 of an inch off. The resond I pulled them out was because it was spuddering, badly. Should I replace them, or could my problem be a gap in the intake boot letting in to much air because it ran hot enough to change my fmf pipe a rainbow color.
Old Oct 19, 2000 | 09:37 PM
vmaxer's Avatar
The reeds being warped will cause the blaster to run rich also if boot is cracked it will run lean. replace asap.
Old Oct 20, 2000 | 02:18 AM
Motordude0616's Avatar
Flip the reeds around thta will tighten them back up.
Old Oct 20, 2000 | 04:45 PM
HILLSVILLE69's Avatar
motor dude i had a newer pair of boyesen reeds and i flipped them over cause there was a gap the other way , there was still a gap when i flipped them over
so that doesnt always work
Old Oct 22, 2000 | 10:24 AM
So basically I need to replace the reeds and check the air box boot for cracks? Is there anything else that could cause it to sputter and barly take off?
Old Oct 25, 2000 | 02:56 PM
timewass's Avatar
Not to be a smart a$$, but how is your plug? 2 strokes are picky about the spark they get.
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
