raptor 350 starting probs
Old Aug 26, 2005 | 04:52 AM
topbuzz's Avatar
Default raptor 350 starting probs
I have just bought a 350 and the thing won,t start there,s a clicking noise from under the seat,also it has misfired and won,t idle right can someone tell were to start looking.
Old Aug 26, 2005 | 08:58 AM
Pitfan04's Avatar
Sounds like a cilanoid problem. Pop your seat and push down on some of the connections around the battery. Find what is clicking and push down on it, make sure everything is tightly screwed. My 660 did the same thing and it turned out my pos. cable came loose on my battery.
Old Aug 26, 2005 | 01:46 PM
hondabuster's Avatar
If it wont start...how do you know theres a miss?
Anyway, if cleaning the battery terminals doesnt work.... have the battery load tested, its probably a marginal battery.
If the idle is poor...it could be lots of things. Start with cleaning and reoiling the air filter, and make sure the gas is fresh.
Old Aug 27, 2005 | 02:26 PM
topbuzz's Avatar
thanx i,ll check them out
Old Aug 27, 2005 | 02:53 PM
recon99's Avatar
The misfiring and weird idling sounds like a problem I had with my warrior before, and it's doing it now again. Check the rubber manifold boot between the carb and the motor for cracks. I also have the problem with the clicking noise and no starting from the battery cables coming loose or getting corroded. Once you get the motor running try pushing the carb side to side, and up and down and see if it misfires or acts up worse from it being moved. If it does then you either have a crack in the manifold or it's not sealing up right at the ends. hope that helps
Old Sep 5, 2005 | 05:17 AM
topbuzz's Avatar
thanx i will try those things out.
Old Sep 5, 2005 | 04:12 PM
420rappy's Avatar
when i put the second tank of gas in mine, it wouldn't start or idle. I was freakin out but it was just bad gas. What was weird was i just bought the gas. But i drained the tank and put fresh gas and it was fine
AtvManiac78
Jul 11, 2015 03:20 AM
Dabears1983
Jun 23, 2015 04:59 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
