Need Raptor Compression Info
Old Sep 12, 2005 | 07:46 PM
maddog56's Avatar
Default Need Raptor Compression Info
I've got a stock bore 11:1 compression wiseco piston and I need to know what the compression spec should be. I know stock is about 182psi, but I need to know for the higher compression. Thanks guys.
Old Sep 13, 2005 | 12:32 AM
HughJazz's Avatar
I a perfect world 1:1 compression is 14.7 so 11:1 should be 161.7
Old Sep 13, 2005 | 06:06 PM
maddog56's Avatar
Yeah I thought about that one, but the equation didnt seem to hold up to the info I had. The manual says 181 psi @ sea level so I was thinking it would be in the low 200 range.
Wiseco couldnt tell me, they guessed in the 220-230 range. Then they told me stock was in the 147 area and any subsequent engine configuration would be the same because of the decompression mechanism, but since mine is gone it doesnt apply either.
Maybe I'll just have to stick with the leakdown and go from there. I'm suprised no one has this info lying around somewhere, its a pretty common compression for this bike.
Thanks Hugh the help is appreciated.
Old Sep 13, 2005 | 06:13 PM
UBETRUN's Avatar
My 12.5:1 is 200 psi, no decompression mechanism.
Old Sep 13, 2005 | 08:36 PM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Not many have checked cranking compression because of the auto decompression.If head work has beed done unshourding the valves will loose a little also. I will check my 13.5 when I go back together all freshened up.
Maddog who did your intake and manual decompression setup? Looks famaliar?
Old Sep 13, 2005 | 09:41 PM
maddog56's Avatar
UBETRUN, thanks that gives me a decent benchmark. Now I have an idea as to what range I'm looking at.
Scholle, good points. I'd appreciate the numbers when you get around to it. I'm sure I'll be going higher comp before too long so these numbers will help in the future as well as now. Barker did my head and intake and I had him throw the decomp on since he was already in there.
STLyamwar
Jul 25, 2020 04:44 AM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
