How to change a sprocket
its quite simple, take off the left rear tire, then bend out the tabs over the bolts holding on the sprocket....unscrew bolts take out sprocket, do the steps backwards....i cant remember about the front though, i think its just a nut holding it on
Ok ran into a problem! Can't loosen the chain!!! I can get the top bolts loose, but the bottom just won't! Can't get in there with a socket and there both starting to strip! What size are they? the bottom ones? a 17 and a 14? thanks
i used a breaker bar over the wrench and a buddy on the other nut. not sure what size it was i want to say 15 and 17 mm[img]i/expressions/face-icon-small-confused.gif[/img]
Yea, I went to tighten my warrior's chain the the bolts almost stripped out... that was really bad.. I would recommend just taking them completely off and replacing them with some grade 5 bolts... The are really strong and harder to strip out. The local Hardware store should have em, just take the origonal bolts in and make sure they are long enough.
