Raptor a-arm removal.
Old Sep 21, 2005 | 07:27 PM
de8212's Avatar
Default Raptor a-arm removal.
I need to remove the a-arms on the raptor. How do I get it off near the hub/wheel.? Just remove the cotter pin and it just slides out? Or is there a trick to it? ALso do I need to remove the brake lines? What steps to do that?
thanks.
Old Sep 21, 2005 | 07:40 PM
sixsixT's Avatar
If your talking about getting the ball-joint sepperated from the spindle you need to use a tie rod fork that wedges between the ball-joint and spindle. After taking the nut off of corse.Or if you don't have a fork you can put some pressure on the joint and then smack the side of the spindle where the ball-joint goes thru it to get it apart but don't cry to me if you make some marks in the spindle or break something.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 21, 2005 | 07:47 PM
de8212's Avatar
Yes. i'm talking about where the ball joint goes into the knuckle.
Hate to ask but what is a tie rod fork???? Is that a tool?
Old Sep 21, 2005 | 08:11 PM
sixsixT's Avatar
Yes a tool.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
