Good deal on Banshee?
Old Sep 25, 2005 | 05:43 PM
RadRaptor's Avatar
Default Good deal on Banshee?
98 Banshee, Pro Circuit pipes, reeds, stainless steel water pump, bored .40 over, new rod , crank, Vito's piston's, ITP Holeshots, baja type rims. Newly rebuilt. What ya think for $2200?
Old Sep 25, 2005 | 05:57 PM
DavidLT250S's Avatar
thats seems like a great deal if the frame and everything is in good shape
Old Sep 25, 2005 | 11:10 PM
RadRaptor's Avatar
I am going in the morning to get it. Guy said mechanically sound, starts 1st kick. Nothing bent, frame great. Thought it was too good to pass by.
Old Sep 26, 2005 | 01:02 AM
BURKEDADDY's Avatar
heres a post from holyman on the bansheehq. good info here. make sure to do a compression test before you buy it.if you dont have one buy one, its a must have tool for the banshee.
Start from the front and work your way back.
Get it on flat ground and look at it. Does it look lop-sided, the plastic fit tight, bars bent, rims look straght up and down and not tipped in at the top. {some aftermarket arms will look tipped in at the top}.
Grab the top of the tire from the side and push it and pull it. There should be no looseness. There is it could be wheel bearings, A arm ball joints, loose pivot bolts or worn out pivot bushings. While you're there look closely at the frame for bends or cracks where the brackets are that hold the A arms to the frames.
Grab the tire from the side one hand front and one hand back and move it like you're turning the bars. Looseness could be tie rod ends or wheel hubs.
Move to the front of the quad and grab the upper A arm and pull it forward and push it back. Looseness here is worn pivot bushings or loose pivot bolts.
Push down on the front bumper and notice any clunking especially at the shocks or front hubs. Notice how easy it is to push down for strength of the shocks.
Look at the radiator for dents or repairs. Look at the fit of the rad plastic to the front fender. A crooked fit shows the bike was rolled and the steering hoop has been bent back. Look for discolored plastic or cracks. Take the plugs out and look at the color. They should be nice and clean and not burnt, melted, or black. Screw in your compression tester. Go around and check the oil. It should be clean and not smell burnt and should not look like chocolate mousse. Silver flecked oil is NOT good.
Get on the quad and sit on the seat. See if the bars and pegs feel like they're in the right place. Move bars and listen for noises or looseness. Could be top stem bushing, lower stem bearing, tie rod ends, A arm ball joints or bad hub bearings. Stand up on the pegs and bounce all of your weight on one of the foot pegs and then the other. Listen for clunking or movement other than the squishiness of the tires. Looseness or noises are usually swingarm pivot bearings or axle bearings. Sometimes loose rear wheel hubs will thump a little. Look at the pegs too for bends or looseness. Bounce up and down on both pegs at the same time and listen for noises usually in the rear at the shock. Move the throttle a couple times and try to notice any snags or rough spots. Hold the throttle open and kick the kicker until the compression gauge won't go any higher. Write down the compression. Do the second one and record the number. Less than 100PSI compression or more than 10% difference between the 2 numbers means top end time.
Get off the quad and take off the seat and filter top. Take out the filter and see if it's clean and run your finger inside the carb. Any grit or dirt means bad filter maintenance and NOT GOOD for the motor. Check carb tops to make sure they're tight. Check crossover tube or boost bottle for grooves from the cables rubbing.
Put the filter and seat back on.
Get off the quad and look at the grab bar where it meets the frame. This spot usually gets bent from back flips. Grad the rear bar and lift hard and lsiten for noises especially at the shock and linkage as well as the swingarm pivot and axle bearings. Grab the bar and push it side to side. This is another way of seeing if the swingarm pivot or the axle bearings are bad. Check the chain and sprockets for looseness and bent/ worn teeth on the sprockets.
Check the tires for uneven wear and check the plastic for discoloration or cracks.
Start it up and let it get warm. Alot of smoke for the first few minutes is not unusual. Clanging noise on the right while it's idling is probably the kicker. Reach down and hold it to see if that's it.
Rev it up. It should rev freely. Go for a ride. Power should be even with no significant hesitations and no bogging. Check brakes front and back. They should stop well with no clunking and no grinding. Come to a complete stop and hold the front brake rock forward and back and listen for clunking. Could be loose A arm bushings, hubs, ball joints, front discs, and calipers.
Hold rear brake and rock front and back. Noises could be swingarm pivot bearings, axle bearings, loose caliper or caliper bracket, or loose brake hub or caliper. Get moving again and go back and let it coast to a stop. Listen for anything unusual. A slight rubbing/ whirring sound is probably the chain slider.
Old Sep 26, 2005 | 10:54 PM
RadRaptor's Avatar
SWEEEEEEEEEEEEEEEEEEEEEEET! Got the Banshee today. I offered him 2k cash and he took it. I'm in love. LOL.
Old Sep 27, 2005 | 09:17 PM
congrats man!! try to get some pics up i am interested in what this beast looks like
Old Sep 27, 2005 | 09:30 PM
TehWarriorGuy's Avatar
man that sounds like an awsome deal!! [img]i/expressions/face-icon-small-tongue.gif[/img] get some pics now!! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 28, 2005 | 01:19 AM
RadRaptor's Avatar
O.K. i'll work on the pics. Nice shape too, no cracks in plastic, new seat cover, stickers. I'll get right on it. Damn thing hits and pulls hard. Unreal.
Old Sep 28, 2005 | 01:28 AM
RadRaptor's Avatar
Got a couple questions for ya guys. If I want to change premix, do I just run out whats in the tank then switch. It has R2 32:1 right now. Was thinking about running Klotz. Which do you recommend and stay at same ratio? He said it hasnt fouled a plug since rebuilt.
Also: Should I be babying it since it has been rebuilt and for how long. Been about 5 gallons of gas run through it since rebuilt. When should I change gear oil and what do you recommend?
1 more quick question. It has stock air filter setup and cheap filter. If I change to the Pro Design with K&N will I have to rejet it by just changing filter. It is already jetted and didn't want to mess with rejetting it.
Thx and I really appreciate your responses. Mike
Old Sep 28, 2005 | 02:14 AM
BURKEDADDY's Avatar
just use whats in the tank then switch over to klotz r50 thats the brand i ended up choosing after doing some research. 40 to 50 to 1 ratio.youll need a ratio rite cup, makes mixing easy.if it has 5 gallons through it, the break in is pretty much over in my opion. the real question is are you broke in for the banshee[img]i/expressions/face-icon-small-smile.gif[/img]. as for the gear oil belray gear saver is what i ended up getting with a magnetic oil drain plug, around 12 dollars shipped and a good investment.any time you change from one air filter setup to another your changing how much air the engine is getting and youll have to compensate by jetting it to get the mixture right again.also an inline fuel filter would be a good upgrade and cheap insurance for around a dollar and fifty cents.if it still has the parking brake and tors system on it that would be the first things to go if it was me. and theres almost endless options for the banshee tons of aftermarket.
the only thing i know for 100% sure is that you will have fun
almost forgot get a clymers guide.
