Need Banshee Help Qucik!
Old Sep 28, 2005 | 04:13 PM
RadRaptor's Avatar
Default Need Banshee Help Qucik!
Just got this Banshee. Checked oil today and was LOW! Something didn't seem right. I looked down and seen wetness. At first i thought the gasket was leaking or a loose bolt on the side cover. After looking harder it looks like the seal on the kickstart is leaking. It is in cockeyed. What do I need to do to fix it quick. I need to buy a manual i know that already. Just give me a quick rundown PLEASE. Pretty simple fix im thinking right? Thx fellas. GLAD I DIDNT GO FOR A RIDE!
Old Sep 28, 2005 | 04:19 PM
zzz1's Avatar
buy new quad banshees suck
Old Sep 28, 2005 | 04:32 PM
RadRaptor's Avatar
That is pretty rude. Glad everyone on this site isn't like that. No place for people like that here. Anyways:
I just went outside,yep it is definitely that seal. I took the kick start off the shaft. Does the seal go in from the outside or do I have to take the whole cover off and everything and put it in from other side. Looks like if i can get it back out where it is cockeyed i can press it in str8 and wala. Help me out fellas. Thx.
Old Sep 28, 2005 | 05:53 PM
QaudMan's Avatar
zzz 1 I agree with you 100%
Old Sep 28, 2005 | 05:54 PM
garyc660R's Avatar
I just went to www.albaaction.com and looked up that seal. By the diagram in the parts fiche, it certainly appears that the seal simply pushes right it. Here is the part number for an 02 Banshee (probably be a good idea to look up your particular model).
93102-20484-00 It runs a couple of bucks. Guys, if you can't help this guy out, then leave your rude comments out of his thread. Thanks!
Gary
Old Sep 28, 2005 | 06:12 PM
Trxoutlawz's Avatar
Rad....
Gary has some good info there.. You might want to pick up a service manual for future use when you get a chance.. go to alba's site and look through the oem parts diagrams and you will see how it all goes together.. Good luck on the repair..
Also.. Sorry to see so many rude comments for no reason.. There are far too many dumb a$$ punks on this site.. You just have to weed through them..
Old Sep 28, 2005 | 06:19 PM
paintballbanshee's Avatar
banshees suck?? ur an idiot
Old Sep 28, 2005 | 06:22 PM
RadRaptor's Avatar
Got r' done fellas. Took kicker off and pulled seal out and pressed it back in. Wasn't damaged just in wrong. I'll keep an eye on it. Thx for your help guys. I bought a couple quarts to change oil. Is that about what the capacity it? Banshee's rule!
Old Sep 28, 2005 | 06:28 PM
fing's Avatar
OHHH hip hop hooray for Mr. 660r. Hey gary are you sure you got your facts straight on your heroic efforts to help your fellow member with his complicated shifter seal issues and dilema I'm sur your very important data will make a huuuuuuge difference on the future of this guys 1987 bash!t. You were sure as he!! wrong with your procom info, you other guys should check it out its almost worth a laugh or too, him and maddog there.
Old Sep 29, 2005 | 01:17 AM
RadRaptor's Avatar
What a great guy! It sucks all that running your mouth you do and can't even read. I feel sorry for ya cuz I don't own a 1987 Banshee. ANYWAYS. Thx for lookin out for me fellas. What exactly is the TORS?
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
