Banshee Mods
Old Sep 28, 2005 | 11:35 PM
00twin350's Avatar
Default Banshee Mods
What are some of the easiest mods cheapest mods and best mods u can do to a banshee to make it go faster its a stock 01 what would u reccomend i do 1st??
Old Sep 28, 2005 | 11:38 PM
warriorguy22's Avatar
pipe first
Old Sep 29, 2005 | 12:09 AM
Trxoutlawz's Avatar
First off, what do you ride.. how do you want to ride..??? Give us some info as to the conditions you ride in..
Not all mods are best for all conditions.. How much do you want to spend? Nobody knows what mods will be of any use to you if you do not give out some info..
Old Sep 29, 2005 | 04:26 AM
BURKEDADDY's Avatar
if its stock get some pipes first.second id get a cool head with some smaller domes to up the compression and help with cooling.a magnetic oil drain plug and a inline fuel filter are a good idea for under 15 dollars.parking brake block off.and take off the tors system.or you could get some aftermarket shocks.
how much are you wanting to spend is the real question? skys the limits for mods on the banshee.
Old Sep 29, 2005 | 06:10 AM
enFORCER's Avatar
pipe's and a adjustable timing plate is a good start...
Old Sep 29, 2005 | 12:45 PM
ZillaRider02's Avatar
Better tires, YFZ450 shocks, Pipes, Pro Design Air Filter, Water Pump Impellar, wider axle, the list goes on....
Old Sep 30, 2005 | 12:42 AM
00twin350's Avatar
i usually ride at Mt.Morris michigan lots of trails and in kalkaska lots of sandy trails speed...my limit about i dunno how much is a good cheap pipe is there a website i could go to price it all out?
Old Sep 30, 2005 | 12:47 AM
RoostItUp's Avatar
If your lookin for good inexpensive pipes you might want to check out FMF's products. They have alot of different pipes for whatever kind of power your looking for. FMF <--Click
Old Sep 30, 2005 | 10:14 AM
slapahobanshee's Avatar
i would do pipes a milled head and timing plate and reeds and clamp on filters
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
