help quick
Old Oct 6, 2005 | 10:54 PM
UltimateAussie's Avatar
Default help quick
my warrior has justr stopped startting it will start if you tow it and then pop the clutch but it wont start on its own i hook it up to the battery charger and leave it and it still wont start i also swithed solonoids. please help me quick
Old Oct 6, 2005 | 11:56 PM
TJw6981's Avatar
Default help quick
My 00' warrior did this... It turned out the rings were bad in it. Maybe its the same for yours. Before you do that check your spark plug, Good luck
Travis
Old Oct 7, 2005 | 12:44 AM
blindside350's Avatar
Default help quick
Could you need a new battery? maybe something wrong with the starter motor
Old Oct 7, 2005 | 12:46 AM
RoostItUp's Avatar
Default help quick
Check your battery, it might need to be replaced. Thats where I'd start.
Old Oct 7, 2005 | 01:51 AM
Default help quick
o yeah i forgot to mention the big thing. it just goes click. only once per time i hit the starter button. its times like these i wish i had the pull starter from an early model warrior,. but please i still need help
Old Oct 7, 2005 | 02:40 AM
RoostItUp's Avatar
Default help quick
Did you checked the battery or have it checked by someone?
Old Oct 7, 2005 | 03:04 AM
RadRaptor's Avatar
Default help quick
If it is just clicking i'd be willing to bet the battery. Always start at the simplest solutions first. Good Luck!
Old Oct 7, 2005 | 11:58 AM
Default help quick
i checked the battery but couldnt get a solid reading. i think i might replace it tonight. i think i may have cooked it when i accidently left the charger on 50 amp engine start for too long. whoops i think i might have found my problem thanks guys
Old Oct 7, 2005 | 03:57 PM
TJw6981's Avatar
Default help quick
Yea the clicking is a dead giveaway... not enough battery power to turn the starter. Keep us posted
Old Oct 7, 2005 | 04:15 PM
RacinJason's Avatar
Default help quick
I'd say the battery is toast...especially after getting cooked on the charger.
