Ticking Raptor ????? Valves ????
Old Oct 8, 2005 | 01:30 AM
FsT4WrD's Avatar
Default Ticking Raptor ????? Valves ????
I have never worked on one nor have I rode one. My neighbor has had one for about a year, this is his first quad and first 4 stroke, he adjusted the valves for the first time, he has a manuel and followed it closely.
He adjusted the valves about a week ago but has not rode it, today he comes over and asked me to take a listen since he sees me working on mine all the time. I started it up and its pretty noisey but sounds more like a loose cam chain slapping then valves. He told me valves are in spec, it took 6 to 7 turns to get them in spec. after adjusted he said it started up better then usual and sounded great, now all the sudden its ticking like crazy.
Any ideas ? Z's are known for timing chain slap and mine did it and his sounds the same as mine did. It doesnt go away when you rev higher, it just increases ticking with RPM's.
Thanks
Old Oct 8, 2005 | 01:45 AM
LivinInVegas's Avatar
I can tell you that it's not normal to tick. But I can't diagnose unless I have more info on the bike. Year, hours on the motor, mods if any?
Old Oct 8, 2005 | 01:51 AM
FsT4WrD's Avatar
I will find out more info this weekend, all I know is he only rides dunes, its the Black with red flames, and he has an Alba pipe on it. Dont know if he bought it new or used. Today was the first day I have really talked to him, its always been just a friendly wave. Your in Vegas you know how it is, most neighbors just look at ya funny. LOL
Old Oct 8, 2005 | 07:50 AM
sixsixT's Avatar
It sounds like he didn't have it on compression stroke or he used the wrong specs.
Old Oct 11, 2005 | 12:24 AM
snowman13's Avatar
hello, i'm the friendly neighbor!! found this site from many internet searches, trying to find more info to make sure my raptor will run right, It is an '03 LE raptor black with red flames, i bought it new it ran really good then i put an Alba full exhaust on it, DynoJet Kit Prodesign air filter adapter with a K&N filter, i also dropped a tooth on the front sprocket. other than that it is stock, and it has always ran VERY GOOD. the manual only says to have the piston at TDC with all the adjusters (exhaust and intake) in the Up position, it never specified wich stroke. just that the "I"mark on the timing gear is in alignment withe the mark on the case. any advice or info anyone can give me would be greatly appreciated, thanx
Old Oct 11, 2005 | 12:30 AM
caliraptor's Avatar
Read this that should help you out.
Old Oct 11, 2005 | 01:09 AM
snowman13's Avatar
thanx for the link, thats more info than my manual and the yamaha shop gave me, thanx again
Old Oct 11, 2005 | 01:24 AM
caliraptor's Avatar
no problem, were all friendly neighbors here [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 11, 2005 | 02:50 AM
CTracingraptor's Avatar
a little tick its a problem, make sure your on teh right stroke when your adjusting them, and/or is could be a little piston slap.
Old Oct 12, 2005 | 12:31 AM
snowman13's Avatar
It Lives!!!!! i adjusted the valves on the right stroke this time and it's running like a bat out of hell again. thank you for all your help, and thanx neighbor for getting me headed in the right direction.
i'm just trying to figure out these 4 wheels, and 4 strokes
