outerware on foam ??
Old Oct 8, 2005 | 04:30 PM
UltimateAussie's Avatar
Default outerware on foam ??
will outerwares work on foam filters. i know they ciome with a prefilter but i like the water resistants of a uni has any one tried this, i was thinking about not oiling my outerfilter on the uni so the outwerware doesnt stick thanks
Old Oct 8, 2005 | 05:11 PM
thewayout420's Avatar
i run a outerwear on my twinair foam filter,it seems to healp out alot..
Old Oct 8, 2005 | 08:42 PM
any one else with thoughts. come on ive heard of it a lot someone else has to have dont it too
Old Oct 8, 2005 | 09:48 PM
LotusPosition's Avatar
I use one on my Uni, it saves a lot of filter maintainance.
Old Oct 8, 2005 | 10:19 PM
tdragano's Avatar
When you purchase Mickey's (Four Stroke Tech - FST) Hi-Flow air intake kit, it comes with a Uni-Filter foam filter and an OuterWears. If you haven't tried it yet, K&N air filter cleaner works GREAT for cleaning the OuterWears and the foam filter. I was skeptical of the K&N cleaner at around $10, but it is worth every penny.
I oiled the foam filter real well, did not purposely oil the OuterWears. Some of the oil from the foam will soak through though.
Old Oct 8, 2005 | 10:37 PM
sweet i thinkim going to do it when i get the funds
Old Oct 9, 2005 | 01:24 PM
HappaRap's Avatar
Lazy Boy Rider!
Guess I don't understand the reasoning for a prefilter on foam, are you putting it on so you don't have to oil it? The foam is dense enough not to let anything pass through, especially after being oiled, a prefilter yes on a gauze filter, but foam?, I would never see the need for it.
Old Oct 9, 2005 | 01:41 PM
if i was using a airbox with my foam clamp-on filter,i probably wouldnt be using a prefilter.running without the airbox i like using the prefilter to help keep the mud and whatever else off my filter,its also water resistant.my filter stays cleaner between cleanings using the outterwear and it will also last longer using one..
Old Oct 10, 2005 | 12:47 AM
HappaRap's Avatar
Lazy Boy Rider!
Originally posted by: thewayout420 if i was using a airbox with my foam clamp-on filter,i probably wouldnt be using a prefilter.running without the airbox i like using the prefilter to help keep the mud and whatever else off my filter
Now, I agree with that, if you're not using an airbox with a foam filter, by all means, use a prefilter. When I run my 660 with no airbox and a K&N gauze filter, I always use a prefilter.
1986Vmax540
Jul 9, 2021 09:53 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
mbriggs
Sep 13, 2015 10:47 AM
Steeldon
Sep 9, 2015 09:38 AM
