How to bleed brakes.
Old Oct 10, 2005 | 09:18 PM
CanadianGM's Avatar
Default How to bleed brakes.
Hey,
Whats the best way to bleed brakes? I minstalling a new front system and need to bleed them.
Old Oct 10, 2005 | 09:27 PM
RacinJason's Avatar
Install the mast cyl and lines and fill the resv with fluid...slightly crack the lines loose at the wheel until fluid comes out...make sure to clean up the spilled mess
Then simply pump the brakes and hold the lever down while you open the bleeded and close it
IMPORTANT not to release the lever while you have the bleeder open
continue this process until you don't get air cmoming out with the fluid
Remember to refill your resv as you bleed the brakes
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
toonces
Aug 25, 2015 06:09 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
