jetting questions yfz450
Old Oct 14, 2005 | 08:50 PM
jusin23's Avatar
Default jetting questions yfz450
allright guys got a few questions i have a 04 yfz 450 just put on a armor tech pipe, pro performance air filter, and a gyt-r jet kit from yamaha. i am setting at 231 ft above sea level i used jet #165 main , 42 pilot 3rd from the top needle clip position and 3 turns out on the pilot screw at first i had the lib off the box and it would hardly run then i put the lid on and it started much easier just wouldnt idle i would have to give it just a tiny amount of gas to keep her running so i screwed in the idle screw enough now she will idle runs like a scared ghost almost scary but i noticed when i get in it and let of it is doing alot of backfiring just wondering which move i should make from here to try to alleviate the promblem thanks
Old Oct 14, 2005 | 08:52 PM
HughJazz's Avatar
Go up to a 45 pilot and then try the 4th clip on the needle
Old Oct 14, 2005 | 08:56 PM
jusin23's Avatar
man i didnt want to hear that i hate the thought of having to take the carb off again lol especially if it is still not right
Old Oct 14, 2005 | 08:59 PM
DirtDragon's Avatar
Don't have to remove the carb!
Just loosen it up and twist it to the side (Not too far as the cables become tight). from there you can get pilot&main jets. Then unscrew gas tank and turn sideways. Now you can get the top off the carb with the proper t-handle allen wrench and adjust the needle. 15 mins tops once you do it a couple times.
Good luck!
Old Oct 14, 2005 | 09:07 PM
jusin23's Avatar
thanks man i really appreciate do u agree with him about the his recommendations not doubting just like several inputs
Old Oct 14, 2005 | 09:08 PM
jusin23's Avatar
oh yeah which side throttle side or shifter side should i twist it to??
Old Oct 14, 2005 | 11:31 PM
HughJazz's Avatar
Twist the bottom to the clutch side. Rotated it clockwise if you where looking at it from the back
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
