raptor 660 suspension
Old Oct 19, 2005 | 03:51 PM
cgalle8103's Avatar
Default raptor 660 suspension
hey everyone i have an 04 660 an ride with a friend that has a 04 yzf 450 where we ride are alot of whoops and he always smokes me in them well the other day i took his quad for a ride and figured out its because of his stock suspension i heard you could take the stock front shocks off a 450 and they would bolt right up to a raptor has anyone ever done this and is it worth the buy please reply thanks
Old Oct 19, 2005 | 04:38 PM
skii0's Avatar
i say go for it...there is just a minor modification you have to do to make them fit....
Old Oct 19, 2005 | 05:44 PM
cgalle8103's Avatar
what mod do you have to make i heard they bolt right up
Old Oct 19, 2005 | 06:10 PM
Raptor0502's Avatar
im pretty sure u have to grind the upper mounting brackets down a little on the frame
Old Oct 19, 2005 | 06:24 PM
cgalle8103's Avatar
has anyone actually tried this to see if its worth the work and if it makes a differance
Old Oct 19, 2005 | 11:13 PM
Topdollr's Avatar
yeah i have 450 shocks on my raptor. Just had to grind away a little material on the upper mount and also remove the inside material off of the bottom mount. You will also have to remove a little material from the shock itself. On the bottom there is more material around the shock mount on the shock itself that needs removed so it can move freely when mounted. Took about 30 minute with a die grinder and carbide bit.
Made a world of difference in the whoops for me. If you have a good deal on a set of 450 shocks then go for it. Not hard at all to mod to fit.
Old Oct 19, 2005 | 11:38 PM
vade's Avatar
The 450 shocks work awesome on the raptor. You do have to do some grinding to get them to work though. You need to shorten the top mount a little bit for clearance. For the bottom mount you need to grind some material out of the A Arm NOT on the shock body itself. The bottom mount on the shock is much thicker on the 450 shock than on the stock raptor shock. If you want some picures let me know and I will see if I can get some decent shots for you. As for the shocks you should be able to find a decent set on Ebay for about 200.00, maybe less. The 06 shocks I think are sprung a little lighter that the prior years so keep that in mind as well.
Vade
Old Oct 19, 2005 | 11:46 PM
velocyraptor's Avatar
i was planning on buying some yfz shocks for my rappy but i wasnt sure if they would fit, will the rappy drop from the front after ive bolted the shocks and VADE could you take some pictures of the mods you had to make thanx
velocyraptor
Old Oct 20, 2005 | 12:25 AM
will i still be able to use the OMF air scoops with the yfz shocks?
Old Oct 20, 2005 | 02:27 AM
vade's Avatar
I have my digital camera at the office but I did some scrounging online and found some pictures that should give you and idea of what you need to do. Let me know if you have any more questions, I'll be happy to help.
Vade
