How to fix a rim. Need help.
Old Nov 5, 2005 | 06:54 PM
PolishCowboyPL's Avatar
Default How to fix a rim. Need help.
I got a good set of tires with rims but one of the rim, the lug stud holes are worn out bigger. How do I fix this. I was thinking to weld washers or a piece of metal with a new hold ontop of it but I am scared that it will weaking the rim and the area where I welded causing it to possibly break. Anyone got suggestions?
Or do I have to get a new rim?
MIke.
Old Nov 5, 2005 | 07:13 PM
DuneRider650's Avatar
I ride a little here and there......
steel or alluminum
Old Nov 5, 2005 | 07:17 PM
Whatever stock is.
MIke.
Old Nov 5, 2005 | 09:04 PM
alluminum...if you can weld alluminum go ahead and weld it. You cannot weld washers onto it or steel they do not bond with alluminum...i would take it to a machine shop and get them to fix it.
Old Nov 5, 2005 | 09:09 PM
I don't want to take it to a machine show cause I can get a new rim on ebay for like 25 bucks. I would like to do it myself if possbile.
I was thinking about welding.. What is the trick to welding aluminum.
MIke.
Old Nov 5, 2005 | 11:14 PM
DavidLT250S's Avatar
when welding aluninum go nice a steady and do not hurry it is alot softer then steel which makes it more easier to melt and if you rush you will totally f*ck your rim over if you are not to experienced with welding I'd get somone else to do it
Old Nov 6, 2005 | 10:02 AM
wfo660r's Avatar
not to mention that if they're not perfectly on center, it's either not going to fit right or give some vibration at high speeds.
Old Nov 6, 2005 | 10:12 AM
bberck's Avatar
Id get the new rim for $25. Picture this you weld wheel and believe you have it fixed, you load up with your buddies for a long day of riding. 10 minutes in wheel is messed up again and you sitting at the truck all day while your buddies ride now ask yourself is this worth saving $25.
Old Nov 6, 2005 | 02:49 PM
Ya I also realized that if I drilled it off that it would wobble. So I'm gonna look for a new rim.
THanks everyone.
MIke.
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
