Raptor 350, 660, or 700??
Old Nov 8, 2005 | 09:13 PM
89warrior's Avatar
Default Raptor 350, 660, or 700??
I need to know witch raptor rear shock will fit my warrior? Anyone know?
Old Nov 8, 2005 | 09:35 PM
DriverDoyle's Avatar
The rappy 350 will fit. the others will not. my back lowering kits is for a rappy 660 and i had to do some mods to make it fit and the reason i done that was a warrior lowering kit was not low enough. and the rappy one slams a warrior.
Old Nov 8, 2005 | 09:43 PM
89warrior's Avatar
So you have a rappy 660 rear shock on your warrior? what mods did you have to do.
Old Nov 8, 2005 | 09:47 PM
NosPredator's Avatar
i have aftermarket rear shockfor warrior not sure what brand butt can give a description of the shock if interested have front aftermarket also off a 2000 warrior
Old Nov 8, 2005 | 10:03 PM
89warrior's Avatar
yes please. what they look like and how old and how used are they. got any pix of them? and how much you want for front and rear?
Old Nov 8, 2005 | 10:06 PM
No not shock i used my warrior shock couse it is sorter i just used the lowering kit. were the shock mount up on your swingarm and fram the 660 shock is a little two wide as is the same thing on a lowing kit. and i used the rappy lowering kit couse its drops you about 1.5 more inches that a warrior one. took me about 2hrs to make it fit.
Old Nov 8, 2005 | 10:16 PM
Look at my new pics you can kinda see how well that rappy lowering kit work on that warrior when you sit on it the finders are about 2 inchs from tires. make it hook up good on roundtrack
Old Nov 8, 2005 | 11:02 PM
89warrior's Avatar
Wow that baby is low!! Looks very good though. Well i found out that a stock rear banshee shock monts right up, but rubs on the air box. Huh wonder if there is some kind of mod i can do to make it fit???? Anyone know?
Old Nov 9, 2005 | 10:37 PM
89warrior's Avatar
I called yamaha today and they told me that the rear rappy 660 shock will fit on my warrior? has anyone put a rappy 660 rear shock on there warrior??
Old Nov 9, 2005 | 10:46 PM
maddog56's Avatar
It's been done quite a few times, but only the 01 rappy rear with the remote rezzy will work. The piggy back has clearance issues.
