Jetting ?'s help please!
Old Nov 27, 2005 | 12:42 AM
pitdawg's Avatar
Default Jetting ?'s help please!
I got my new Duncan exhaust and Pro Design intake with the Uni foam filter no lid installed on my 06 yfz. Rejetted with the following- pilot jet 45, main jet 180, stock needle (non adjustable) and tinkered with the fuel mixture screw and it ran like shizz!!! Very boggy at 1/4 to 1/2 throttle kept dying if I wasnt on the gas. Header glows bright red at night shooting the hill (throttle pinned). Header glows at idle also. When I rev high it seems to backfire. Our elevation at the Dunes is approx 4800 ft above sea level and the temp was about 36 deg all day. So whats up ? any and all advice will be very appreciated.
Old Nov 27, 2005 | 01:17 AM
hondabuster's Avatar
Sounds like alot of lean symptoms, youre gonna need to go bigger on the main jet. Try a running with the lid back on the air box, if it improves, then youll know for sure its too lean.
Old Nov 27, 2005 | 02:15 AM
pitdawg's Avatar
Ill try the lid back on> I was wondering about the needle should I throw in an adjustable one?
Old Nov 27, 2005 | 06:22 PM
You should be able to shim the needle if it needs it, wait and see how it runs, when you get the main jet correct.
Heres a good article on jetting, and at the end of it, theres a list of symptoms of lean and rich, which may help figure out which way you need to go.
jetting
Old Nov 27, 2005 | 08:23 PM
sixsixT's Avatar
Get a stock needle for the YZ 450 F, do a search on the part # I would also get a Zip-ty to replace the idle mix. screw. 180 on the main seems a bit rich for that elevation.
Old Nov 27, 2005 | 09:20 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
NCVQ Needle #5TA-14916-V1-00 that is the OEM YAMAHA part number........
Your 180 Main is to rich for that alt. try going to a 168 or 170.......Good luck [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 27, 2005 | 09:33 PM
nmd3228's Avatar
Does it idle ok? If so leave the pilot alone..I would get the NCVQ needle the last guy suggested and try jetting down to a 175 or. turn the screw 2 turns out until you get the jetting closer and then adjust.
Old Nov 28, 2005 | 10:54 PM
pitdawg's Avatar
I got the dirt bike needle, gonna throw that in. As far as my main I've got a guy who helped me jet this who races in the pro class on a yfz hes got 2 of them and thats what hes runnin. Up top wide open it seems ok. Thanks for all the input.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
