Winch Question
Old Nov 28, 2005 | 01:44 PM
Murph22083's Avatar
Default Winch Question
I just installed a Warn 2.5ci winch on the Grizz. I ran the red power cable that goes to the rocker switch to the ignition, and everything works fine. I did put a fuse holder on that wire going to my ignition. I was wondering if anyone would know what amp fuse I should use. Right now I have a 25 amp fuse in there. Thanks in advance.
Old Nov 28, 2005 | 07:54 PM
HooPharted's Avatar
higher amp fuse means it will take more before the fuse blows,,,,the fuse is there to protect the circuit from a ground,or overload that can result in damage to componants,,,,if it were me i would try an 8,or 10 amp and see how that works
if by normal use it blows the smaller amp fuse,you can always go up
ylomnstr
Sep 22, 2015 12:19 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
ylomnstr
Sep 4, 2015 05:02 PM
