Shee wheels
Old Dec 4, 2005 | 07:28 PM
89warrior's Avatar
Default Shee wheels
Will 22x12-10 fit my stock banshee wheels? And if not what wheels will fit my stock wheels?
Old Dec 4, 2005 | 08:05 PM
DriverDoyle's Avatar
Default Shee wheels
Yeah if you rim is a 10 inch rim it will work.
Old Dec 4, 2005 | 08:26 PM
89warrior's Avatar
Default Shee wheels
I think stock banshee rear wheels are 9 inch?
Old Dec 4, 2005 | 09:14 PM
89warrior's Avatar
Default Shee wheels
Anyone else know anything on banshee wheels?
Old Dec 4, 2005 | 09:48 PM
MDS2106's Avatar
Default Shee wheels
Yes the stock rear wheels are 9",so those tires will not fit.
Old Dec 4, 2005 | 10:36 PM
89warrior's Avatar
Default Shee wheels
So what are all the different sizes I can use on my rear wheels?
Old Dec 4, 2005 | 11:16 PM
TheTurtle's Avatar
Default Shee wheels
the last number is the rim size. that is the only # that really matters when deciding which ones will fit.
Old Dec 5, 2005 | 06:12 PM
Mechanicsn's Avatar
Default Shee wheels
All my banshee friends are running a 20x11-9 rear tire. Just remember if you change the tire size you may have to change sprockets to correct your gearing.
Old Dec 5, 2005 | 06:31 PM
89warrior's Avatar
Default Shee wheels
ok here is what i got. 20x11x9 in the rear with a 44 tooth sprocket and 21x7x10 in the front with a 16 tooth sprocket. what yall thank about that?
Old Dec 5, 2005 | 09:23 PM
bberck's Avatar
Default Shee wheels
Not sure if you putting on a Banshee or a warrior, but that set up on a warrior will give you more high end and less low end than stock. Most seem to want more low end on a warrior but just depends on what you want.
