good clutch for warrior
Old Dec 5, 2005 | 08:00 PM
warriorboy22's Avatar
Default good clutch for warrior
whats a good clutch that will last a long time. i have about 100-150 to spend on a clutch i pop the clutch alot for wheelies so i dont want it to wear down fast.
Old Dec 5, 2005 | 08:25 PM
DriverDoyle's Avatar
Well i think you can get the barnett clutches and springs for around 100.00 to 150.00. but not sure i got the hole system it was like around 550.00 i think i dont remember lol. But i like my barnetts i have not had a prob with them. Just remember what ever you get put them in oil overnight before you install them.
Old Dec 5, 2005 | 08:41 PM
AZDUNERAT's Avatar
Barnett dirt digger cost me 100.00 and I ride sand alot. Clutch has held up fine for the last 4 trips no problems at all!
Old Dec 5, 2005 | 08:45 PM
89warrior's Avatar
why do you have to let them sit in oil over night? i did not do this the my clutch......? the engine is not in the quad and will not be for around 3 or 4 months down the road. can i just fill the case with oil and let it sit like that? or should i take it all back apart? o by the way i got the EBC dirt racer for around $75 shipped. dont really know how she will hold up yet.
Old Dec 5, 2005 | 08:51 PM
doesnt your motor oil lube the clutch and if you let it soak in oil wont that cause slipping
Old Dec 5, 2005 | 08:56 PM
Yes i would take them back out. and put them back in before you get ready to use them. You soak them in oil (90w) becouse the clutchs will soak up the oil. if you put them in dry they will not wear right and could slip. You need to take them out put them in a big bowl or something they can lay flat in. and let them soak
Old Dec 5, 2005 | 09:05 PM
89warrior's Avatar
ok thanks will do
is the ebc a good clutch that will last a Long time i still have the stock clutch in there and its been ridden alot and its not slipping that much. will the ebc last longer then the stock one i understand the whole you get what you paid for and its only about $75 for the ebc clutch kit and i think that kind of cheap.
Old Dec 5, 2005 | 09:09 PM
89warrior's Avatar
cheap? you think $75.00 is cheap. Lol the barnett clutch is only $25.00 more but $75.00 is cheap. wow!
Old Dec 5, 2005 | 09:17 PM
Boys lol If you really think about it. It is the cheap way to go. Go and price a clutch system. my barnett system was around 550.00. Two of my buddies run HINSON systems you talking about over 1000.00 For them. One of them is on the furums AustinOneal He has a Bob Craycraft built rappy he can tell you about clutchs lol He has shatterd a few [img]i/expressions/face-icon-small-wink.gif[/img]
