what kind of pipe?
Old Dec 20, 2005 | 07:45 PM
Tyayo420batavia's Avatar
Default what kind of pipe?
i was wondering what kind of pipe and filter air, is the best for a yamaha timberwolf. i want to replace some of the stock parets but im not sure what is a good pipe for it and clutch kit if there is one is good also.
Old Dec 21, 2005 | 11:59 PM
Does anybody know anything i can do to this machine??????
Old Dec 23, 2005 | 07:33 PM
recon99's Avatar
Best exhaust depends a lot on how big of an issue noise is. I personally would go with an hmf slip on, they are a pretty versatile exhuast. They look good, sound good, and have the option of a quiet core to keep noise levels down. Air filters also depend mostly on what kind of riding you do. K&N filters flow better than any others, but in dusty conditions they can let small particles of dirt through. If you don't ride in dusty dry areas a lot go with the K&N, they are the most expensive of all filters, but give the best power gain, and are very simple and cheap to clean. If you ride in dusty conditions then a dual element foam filter like a UNI or TwinAir is the the best way to go, since they do a better job of capturing small particles. With either filter an outerwear filter cover is a good investment, especially if you ride in wet muddy conditions.
Old Dec 23, 2005 | 07:58 PM
recon99's Avatar
Well, I just checked and hmf doesn't make a pipe for the timberwolf yet. I just checked a couple other good compaines, big gun and pro circuit, but they don't make any for the timberwolf either. I'll let you know if I find any good exhausts.
Old Dec 23, 2005 | 08:17 PM
recon99's Avatar
Well, I looked everywhere I could think of, even on ebay, and could only find 3 kinds of exhaust for the timberwolf. You have Cobra Utility Series, Cobra Quiet Series, and a DG exhaust to choose from. None of these have great reputations, but if you really want an exhaust go with the cobra quiet series. All of these exhuasts have a reputation of being poorly built and engineered, but the dg and utility series are both obnoxiously loud and sound like a lawnmower without a muffler. I don't know much about the quiet series, but it has to be better than the others if it's not as annoyingly loud.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
