warrior clutch kit replacent
Old Dec 25, 2005 | 04:15 AM
bickel76's Avatar
Default warrior clutch kit replacent
i know this topic has been discussed, but i'm planning on replacing my clutch on my 01 warrior. does anyone have any opinions on which clutch to go with or avoid? any advice would be greatly appreciated.
Old Dec 25, 2005 | 01:18 PM
recon99's Avatar
I have an ebc clutch kit, and I think that is the best clutch for the money($65 on rockymountainatv.com). Avoid clutches that seem too inexpensive to be any good, like Tusk clutches. If you want the best and longest lasting clutch available get a DP clutch kit, but they're around $160.
Old Dec 25, 2005 | 06:29 PM
89warrior's Avatar
how do you like your ebc clutch? i have installed the ebc on my warrior but have not had a change to run it yet? any probs with sliping? hows it handle on a hard take off?
Old Dec 25, 2005 | 07:26 PM
DriverDoyle's Avatar
I have a Barnett Dirtdigger Clutch System They run about $550.00 Or So... But if you dont need a basket.. Pushplate...and so on. You can get the Clutches and springs for around $100.00.. I have had good luck with them.. I dont know about the rest iv only used barnetts and Hinsons..
Old Dec 25, 2005 | 08:32 PM
recon99's Avatar
No complaints about the EBC so far. Pop the clutch and it grabs instantly without even a hint of slippage.
Old Dec 25, 2005 | 11:01 PM
89warrior's Avatar
Thanks for the info recon99!
Old Dec 29, 2005 | 01:31 AM
bickel76's Avatar
well, i decided to go with the EBC dirt racer clutch. when it gets here, i'm sure that i will have some questions while we are installing it. hopefully, it will go as easily as explained.
Old Dec 29, 2005 | 12:30 PM
recon99's Avatar
let us know if you're not sure about anything. Nothing's worse than spending hours fixing something and getting it all sealed back up to find out that it doesn't work right.
Old Jan 6, 2006 | 11:27 PM
bickel76's Avatar
question for you guys that have the ebc clutch. on the factory clutch, one friction plate has a notch that needs to be lined up. on the ebc, 6 out of the 7 have a notch but the first or last friction plate doesnt have any markings. has anyone ran into this problem? if so, any advice would be extremely appreciated.
thanks
Old Jan 6, 2006 | 11:35 PM
recon99's Avatar
mine was like that too. the notches on the ebc are opposite of the stock clutch plates. The one without the notch goes where the stock one with the notch did.
