Blaster carb help
Old Dec 27, 2005 | 10:07 AM
asfasasu3's Avatar
Default Blaster carb help
I bought my son a 28mm Keithin PE carb, and G3 reeds for Christmas. I got it on yesterday but I can't get it to idle. If I turn the idle set screw either direction, it does not change anything. What am I doing or have done wrong?
Old Dec 27, 2005 | 10:43 AM
lethaface's Avatar
I am assuming the stock carb with TORS was on it..Correct?? If so when you removed the tors did you splice and twist the 2 wires together that once connected to the tors?
Old Dec 27, 2005 | 11:12 AM
asfasasu3's Avatar
It had the stock carb with the tors. And no, I didn't connect the two wires. I just un-plugged them under the tank. Will that affect idle? I wondered about the rev limiter but figured it would be at top end. Can I just make a wire to connect the two wires in the plug?
Old Dec 27, 2005 | 11:29 AM
ShadyRascal's Avatar
Those two wires won't affect the idle. Make sure you are screwing the actual idle screw, rather than the fuel mixture screw. The idle screw goes directly in there against the slide and pushes it upward. When you turn that one in there's no doubt you're on the right screw then.
Old Dec 27, 2005 | 12:01 PM
asfasasu3's Avatar
I'm sure I adjusted the idle screw. Problem is, I can run it in until you can't turm it anymore and it doesn't change a thing. I've been searching on other sites, and most people say that the reeds can cause this. The reeds are brand new. I know that you can get some bad products brand new, but I didn't see anything wrong with them. I really can't imagine that being the problem.
Old Dec 27, 2005 | 12:11 PM
lethaface's Avatar
On my blaster when i changed carbsthose 2 wires had to be hooked up to make it run..I was having the same trouble as you couldn't figure it out, took it to a shop and thats what they did to fix it
Old Dec 27, 2005 | 02:48 PM
lethaface's Avatar
I'm sorry i read your first post wrong..I thought you were having trouble rev'ing the motor but after reading it over your having trouble with idle[img]i/expressions/face-icon-small-blush.gif[/img]
Old Dec 30, 2005 | 01:29 PM
fastquad02blaster's Avatar
What's tors? I'm still kindof new at 2 cycles. Just wondering.
Old Dec 30, 2005 | 02:12 PM
lethaface's Avatar
It's that huge peice of junk that sits on top of the stock carb..Tor's is short for Throttle Over Ride System
Old Dec 31, 2005 | 12:41 PM
So is it like a rev limiter? What is it's function and does it hinder performance?
