horsepower??
i recently took my air box lid and filter out, its louder and it seems to have more low end power is this maybe right? cuz i was thinkin im right because k&n filters produce more airflow...so without a filter does it increase horepower or is it imagination? my buddy runs his without it and also has a 1/4 gap between his muffler pipe and the engine and swears to me it improves performance but that doesnt seem right...who's right here??
Let me get this right.. Your buddy is running his quad with a 1/4 in gap between his Header and his head???? If he is.... He is not very smart... First off if he is running a 4 stoke he is going to burn a valve.. It will suck cold air back up into the head...And he will be looseing power becouse it is taking away some back pressure....Your right about the K&N they flow more air so it makes a little power... But you have to have a filter or you going to gum up the carb...
umm last i checked you should never run with out a air filter. taking the lid off your box maybe ok ,but no filter at all nope sorry you'll pull dirt right into your motor and scarr your piston and cylnder wall's and totally screw your motor . plus last i checked all pipes need to be tight against the head of the motor if thats what your saying .
running with out a filter thats just nutz yeah it might give you just a little more hp but not enouph you can feel you do that and youll suck sand in the motor scratch your walls blow a ring and will pry throw out a bearing so thats dumb and as far as a pipe runing with out ones pointless if you want power you got to have a pipe on 2 or 4 stroke so your buddy doesnt know what hes talking about
it would have less low end power... or at least tahts waht i experianced when i took my lid off. ur friend is on crack for thinkin that.... he just probly thinks it is casue its louder... put ur filter back on and bolt his exhaust back on.....
If you removed the air box lid without rejetting it,it's probably running lean now.That's not a good idea.
Sorry I am slow. What is the significance of the 420 comment?
BTW 420, put your filter back on before some swallow's build a nest in there and get on the internet and educate yourself on how engines work. That will innoculate you against the dangerous advice of morons! [img]i/expressions/face-icon-small-sad.gif[/img]
Later
Later
