raptor 80 engine swap
Old Jan 1, 2006 | 11:39 AM
61669's Avatar
Default raptor 80 engine swap
i have read somewhere there is a 110cc 4 speed engine that bolt right on the raptor 80.
does anyone know exactly what engine this is and will it work with the shaft drive and ignition on the 80 . its a 2003.any help much appreciated
Old Jan 1, 2006 | 03:50 PM
PolishCowboyPL's Avatar
Can I ask why you plan on doing this?? I myself haven't heard about this one
MIke.
Old Jan 1, 2006 | 05:55 PM
paintballbanshee's Avatar
not an engine that will bolt right on that i know of. I was trying to put the system off the z250 onto the raptor 80, its a shaft and its strong im gonna try and do it with my dad over this season
Old Jan 18, 2006 | 04:03 PM
worley4's Avatar
For like $800 or so you could really mod your 80, bore, ignition, carb, etc. You should be pleased with the results, plus less weight. My kid loves his. i think front suspension sucks, so I will only invest so much in it. I have thought about converting it to a-arms, but thats alot of work for something he'll outgrow soon. just my opionion.
Old Jan 19, 2006 | 08:26 AM
asfasasu3's Avatar
The old Yamaha Champs were 100cc and a 4 speed. It is the same engine as the 80. In fact, you cab buy the jug from Yamaha and put it on the 80 motor to do a cheap big bore. The 4th gear was taken out of the Badgers and Raptor 80's to limit the top speed. I have heard that you can modify the Raptors tranny and make it fit, making it a 4 speed. I don't know what would be involved and it might not be cost effective. There are alot of off brand machines out there now that use the Raptor 80 style parts. Maybe one of those would work to get the 110cc your talking about. Good Luck !!
Old Jan 19, 2006 | 11:38 AM
1111's Avatar
go to raptor 80 racing .com ask them they will know all plus you could put alot in to the 80 cc you got know and get it ripping try the raptor80 racing.com site
Old Jan 19, 2006 | 08:33 PM
61669's Avatar
thanx for all the replies i really appreciate the help . my daughter wants to race at the local track and I found out in her class the 4-strokes can go up to 125cc & 2-strokes 90cc but have to have the original case . I already piped , jetted , cdi box , clamp on filter . the quad runs real good I just want her to have the power to keep up with the rest . so I guess a big bore kit is the way to go . again thanks
Old Jan 20, 2006 | 05:00 AM
1111's Avatar
so is that cdi box the procom or the unlimited one with the ac to dc current for stronger spark and and unlimtied revs have you cut the slide in the carb .stock set up only opens half way .
Old Jan 21, 2006 | 12:24 AM
61669's Avatar
Hey 1111 it is the unlimited cdi . I have read about cutting the slide on the 50's but not the 80's . I have no idea how to do that . have you done this and if so any help would be appreciated . I've also read about a clutch kit to help with the holeshot have you heard this one if so is it worth it? thanks again for the input . [img]i/expressions/face-icon-small-cool.gif[/img]
Old Jan 23, 2006 | 12:04 AM
1111's Avatar
unlimited thats cool i'll have to wait i got the pro com that tops out at a point and in terms of cutting the slide i think is the same carb for the 50 and 80 so cutting the slide is easy hit me up if you want to do that it really helps and the clutch kit if they got one go for it i took 8 out of the 12 clutch ***** in the roller to lighten up the clutch and make it engage at higher rpms give it that edge off the line .
Firefighter400
Oct 8, 2022 06:38 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
