+3 A-Arms suspension question
Old Jan 3, 2006 | 02:35 AM
AustinONeal's Avatar
Default +3 A-Arms suspension question
what shocks do i need to buy to go with my +3 and +1 forward a-arms?
do i need long travel or standart or yfz shocks
thanks...
Old Jan 3, 2006 | 03:19 AM
Starky's Avatar
Decide what brand you want to buy and then tell them what a-arms you have. They will tell you what shock will work best.
Old Jan 3, 2006 | 09:19 AM
warwgn's Avatar
some a-arms are designed to use stock length shocks, if this is the case you can run YFZ's depending on how you ride. I would suggest getting them re-valved for your weight, set up and riding style or buy aftermarket shocks.
Old Jan 3, 2006 | 10:49 AM
thats the deal on these ASR a-arms they say if u use stock shocks they will void the warrenty, which leads me to ask what would be better the cheapest works which are about 360 or a set of YFZ's and i guess getting them revalved where ever you get that done.
Old Jan 3, 2006 | 12:42 PM
CoyoteRiverRaptor's Avatar
Austin, I have the ASR +3+1. I use them with the stock replacement Fox Float Shox. It is fantastic and pretty light. I broke one of my Fox shocks over Halloween at Glamis and Fox got them back to me by Thanksgiving under warranty.
While I was waiting for them I got some works tripples without the rez. Good shocks, though they are heavy and harsher in comparison to the floats.
I think you will be happy if you can get a good deal on the YFZ shocks and can get valved properly.
The ASRs combined with the Fox shocks is pretty hard to beat. I think they even help with the weight transfer to let my short 4" swingarm hook up better.
CRR
Old Jan 3, 2006 | 03:52 PM
MasterRaptor's Avatar
+3 is really, really wide. What does this do for you?
Old Jan 3, 2006 | 06:20 PM
warwgn's Avatar
you can get works for what it will cost you to buy some YFZ's and then get them re-valved. If you already have YFZ's then just get them re valved and you will be set, and to top it off works is coming out with a double or tripple rate spring up grade for the YFZ shocks. I will be going that route since I already have some YFZ's once I am done I will post a report on the ride and handeling.
Old Jan 3, 2006 | 07:27 PM
CTracingraptor's Avatar
my suspension guy can get a set of yfz shocks to out preform a set of works triple rates with rezzies($515). just my two cents. thats why i'm having him put them on my raptor and not the works.
Old Jan 4, 2006 | 01:23 AM
+3? Did you go this wide for stability, suspension travel? It seems like you'd hit stuff. What's the deal?
Old Jan 4, 2006 | 01:32 AM
Starky's Avatar
If you want, you can have your stock shocks revalved or put stiffer springs on them. I had the ASR +2+1 and they worked great. I went with Works trip rate and it really smoothed out the ride.
With the +3s it's going to be a little tight on some trails and maybe in the back of a pick-up truck.
