LA Oneway question
Old Jan 19, 2006 | 06:27 PM
raptorgav's Avatar
Default LA Oneway question
After reading somewhere that the cause of the bolts that hold the oneway onto the flywheel coming loose is because the bolts are too long has me concerned that I overlooked this. I seem to think in the kit I purchased that it come with new bolts although I am not 100% sure, can some one help? The article read that you need to use 1mm shorter bolts to solve this problem. I think I used the bolts supplied and cleaned everthing with solvent then used loctite and used the tension they recommended on the bolts, no problem so far. This has me worried because when I pulled down the old 686 my bolts were all loose on the old oneway, although still in the thread. I have read some bad stories of what those little bolts can do floating around inside,broken camshafts etc.
Gav
Old Jan 19, 2006 | 08:38 PM
quadbike's Avatar
I guess you have been to http://www.raptortranny.com/one-wayguide1.php I replaced mine with no issues about 6 months ago.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
