03 raptor 660- what i need to make it stronger ?
Old Jan 21, 2006 | 12:34 PM
arabicdunes's Avatar
Default 03 raptor 660- what i need to make it stronger ?
hello ..
i have 03 raptor 660
if i change (Bore x Stroke) fomm 100 to 102 ? enough ?
is the cams stage 2 enough ? or i need more than that ? and whats the problem i exspect ?
is there any way to beat the banshee on hill climbing????
many question [img]i/expressions/face-icon-small-smile.gif[/img]
sorry for asking .
Old Jan 21, 2006 | 04:43 PM
thedieselkid's Avatar
depends on what the banshee has done to it. Just boring it to 102 mm wont do much. You need a cam ported and polished head, bigger valves help also. Then you will probably need a clutch as well. If you want to hang with the banshees that are built for dragging then you wil need alot more than that. If you want to beat banshees you will probably want to call kms up and ask about their turbo and see what they can do for the motor as well.
Old Jan 21, 2006 | 05:46 PM
thank you
but there no kms in our country
i think i would change for not draging banshee
*(Bore x Stroke) 102 mm
*hotcams stage 2 withe sprig
but what i fread from :
the heat proplem if i mod my atv ? what you think ?
Old Jan 21, 2006 | 05:53 PM
sorry I didn't know where you were from. I will say that a 686 is a good start, and with the proper cam, bigger valves, and good head work that should be all you need to beat a banshee with just bolt ons. but if the banshee has any internal motor work or a good port job then it is all over. The stage 2 is a good cam it works pretty good with the bigger valves and 102mm piston. that is what I have. But right now I am looking into a few cams that are more aggressive. if you go to 102mm then you will want to do some sort of head work.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
