Getting an 02 Raptor
I found a deal on an 02 Raptor for $1200 and I am picking it up on Tuesday. I haven't rode it yet but the guy that I'm buying it from thinks the timing chain is loose because he thinks he hears it slapping. I have yet to hear it for myself but if it is loose then what can be the cause?
MasterRaptor is right on!
The sound is most likely from valve-lash. Ask the guy your buying it from if he's ever had the valves adjusted. If not, that's most likely the source of the "slapping" sound.
Good luck!
Good luck!
For $1200, drop the guy the cash and run if it is in any decent shape. You are probably a valve job away from a great quad.
I would thoroughly check out the quad before you buy it. This deal is too good to be true. If it does need some work, it is so well priced, you can afford to drop some coin into it. With your list of toys, you can afford to drop money into it.
All you really need is a wider axle or rear spacers. This improves handling on the raptor big time. The front doesn't help much for cornering or handling. It just gives more travel and a better ride.
I noticed a significant improvement with the +2 A-arms and +4 axle. With your luck, you can pick it up for an old catchers mit and a quart of bud. A friend of mine called bs when I sunk the money into those two items. He has the same 02 Raptor and it wasn't long before he was convinced and got a similar setup.
If I keep the raptor one of the first improvements will be a wider axle and A-arms. I had +2 front and back on my 440 and it made a HUGE difference. The Raptor sits really high and it's narrow so a wider stance is just what it needs. I also need an exhaust system ASAP. Whats a good exhaust that isn't too loud? I do a lot of full throttle riding and I need something with a lot of mid and top end power.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
