Quick Question about a gasket-Raptor
Old Jan 30, 2006 | 08:14 PM
Z40005BR's Avatar
Default Quick Question about a gasket-Raptor
Hi guys, I am putting a new gasket on the left side of a raptor engine, this is where alll of the starter stuff is. The gasket ripped near the upper part of the case, can I still use it or could I use some liquid gasket where the rip is??
Old Jan 30, 2006 | 08:39 PM
Z40005BR's Avatar
bump
Old Jan 30, 2006 | 10:14 PM
OverRaTeD's Avatar
Runs a DS870 that will flat out Shit and Git!
It is always good to use new gaskets. Reused gaskets are known for leaking. If it were me, I would remove all gasket material from the case, clean it up really good and then use a new gasket. You might get by with a little gasket sealer, but it doesn't take much time to clean up and a new gasket is cheap.
Old Jan 31, 2006 | 03:43 PM
Z40005BR's Avatar
thanks
Old Jan 31, 2006 | 08:22 PM
maddog56's Avatar
That particular gasket can be a real pain in the butt, I have found that replacing rather than repairing is a better option. At least for the side cover anyway. Yamabond by itself wont hold it together either.
Old Jan 31, 2006 | 09:37 PM
Z40005BR's Avatar
Thanks, I just got everything in check and now the engine wont fire. I was thinking I somehow messed up the timing or clogged carbs, because it wont run. I think its the carbs though becuase it has sat all winter without a start
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
