My Raptor died....
Its got compression, fuel, and spark.
My question is, how much compression did it have when you checked it?
who knows, what compression i had, i was in the middle of the dunes, its not like i carry it with me. and if i lost the rings it wouldnt just die like it did, it would just loose power
So your not sure if you have compression? I would check that first. Do you have a JE piston? It could have cracked along the valve reliefs if you do. The flywheel key would be my next guess.
#15
#17
CTracingraptor
It would not be hard to check and see...If you have a 8mm...Just pull your side cover off..and twist your flywheel with your hand..and if you want take your flywheel off and look around...and just see if anything does not look right.....If you got your rappy book it shows you how to do it all in there...Its just kinda hard for me to put in words how to check it....
