kodiak rolls to one side
Old Feb 26, 2006 | 03:59 PM
DonovanC25's Avatar
Default kodiak rolls to one side
Could someone help me out if they have heard of this before. My 04 kodiak that i just bought a month ago seems to sit crooked. when looking at it from the back the right side rear fender and rack is lower than the left side. does anyone know what may cause this or how to fix it. I dont notice it while riding it only looking at it on level ground. the preload on the front shocks is set the same and there is only one shock in the back above the swingarm. thanks for any info.
Old Feb 26, 2006 | 04:49 PM
450kodman's Avatar
is the tire pressure in your rear tires the same?- this would make one side higher than the other
is the rear rack parallel with the rear axle?
Old Feb 26, 2006 | 06:42 PM
rockroller's Avatar
did you buy it new ? if not it sounds like it was rolled and the frame is off a little smae thing happened with my 350 bruin after my buddy rolled it ! we ended up takeing plastice off and with a 2x4 we got her streight agen . 2x4 over left side and under rite side 2 guys sitting on the bike for weight and me liffting the 2x4 . hope this isn't your problem but if it is hope this hlped
Old Feb 27, 2006 | 03:41 PM
DonovanC25's Avatar
Tire pressure is the same all four tires. The rack is not parallel to the rear axle. The right side is about two inches lower than the left. i'm going to check it again with someone sitting on it to see if it makes a difference. Is there some way to check if the frame is bent. I have looked it all over and dont see what could cause it to sit so crooked. I thought it might be something broke on the suspension. Any suggestions?
Old Feb 28, 2006 | 09:45 PM
DonovanC25's Avatar
anyone?
Old Mar 2, 2006 | 10:45 AM
Hebs's Avatar
put a level on it... see how bad it leans... then look at things individually... the rack... the plastics... the mounts for the plastics... look for any kind of bends/kinks and then check to see if they match up to the "good" side....
Old Mar 2, 2006 | 12:11 PM
recon99's Avatar
Yeah, i'd start by taking the racks and fenders off. Look for bends, cracked paint, and rust on the frame and racks.
Old Mar 6, 2006 | 11:01 PM
hutch42's Avatar
If your rack is bent you would see that by doing the following. Take the rack off turn it upside down and slide it on a work bench with the back of the rack against the edge of the bench. If the rack is bent it will not lay flat on the bench. Tweek as necessary till rack lays flat on bench then check rack mounts to bolt holes and bend as needed.
Albertaboyy
Sep 9, 2015 09:51 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
