**RAPTOR ELEC HELP**
Old Mar 7, 2006 | 02:40 AM
rx7racer11's Avatar
Default **RAPTOR ELEC HELP**
MY 03 raptor has been been sitting in the garage for a few months and I tried starting it first i had a dead battery so i charged it and it made a awful buzzing sound in the starter relay when i hit the starter switch .... I thought it was a bad battery so i bought a new one,... same thing bad buzzing sound when you try to start it (engine does not turn over) lights and everything else work but will not start.... so then i thought it was a bad starter relay...... put a new one in and still bad buzzing didnt fix it [img]i/expressions/face-icon-small-sad.gif[/img] I have checked connections at the battery and at the solenoid and tighted it all .... still no engine turn over... I jumped the starter with a screw driver and it started to turn over... so i dont think the starter is bad... (never had probs ) sooo i dont know what to do other than take it to the dealership... any ideas what might be the prob???
Old Mar 7, 2006 | 02:53 AM
HondaAtcRoxz's Avatar
Sounds like to me that your solenoid is bad have you tride to jump the solenoid with a screwdriver???
Old Mar 7, 2006 | 03:50 AM
rx7racer11's Avatar
yea i have swapped out the solenoid already... and when i jump it the engine turns over.... soo is it a bad ground ??
Old Mar 7, 2006 | 06:56 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
clean all the battery/solenoid connection
most likely just some corrosion
Old Mar 7, 2006 | 01:15 PM
AustinONeal's Avatar
yea u got a bad connection i had the same thing happen to my raptor once it just does that nasty buzz noise i tightened up all my batter connections and it worked
Old Mar 8, 2006 | 12:50 AM
rx7racer11's Avatar
turned out to be a bad battery.. thanks for all the help
Old Mar 8, 2006 | 10:54 AM
SmokieDaBear's Avatar
I thought u bought a new battery already?
Old Mar 8, 2006 | 08:41 PM
weatherspoon's Avatar
I have lighting problems with my 03 raptor :for low the lights dont come on at all
:for high it is funny sometimes on elight will come on instead of two
also one light may come on for high but eventually the other will come on to.
Do you think I have the same problem as the other person.
Old Mar 8, 2006 | 08:56 PM
sixsixT's Avatar
I would check the connectors where the headlights plug in.
Old Mar 8, 2006 | 09:10 PM
Dwags's Avatar
yea i would say headlight connections
